Логин:
Пароль:
Регистрация
Забыли пароль?
Форум » Винтажная техника » Акустика, усилители и ресиверы
Страницы: 1
RSS
Victor sea -r7, Сбор информации.
Добрый вечер дорогие формувчане. Предложили этот аппарат на обмен на усилитель. Так вот инфы в инете нет. Нашёл что топовый и какая-то фишка с реверберациями. Не отзывов. Может кто слышал этот эквалайзер. Заранее спасибо.
Изменено: A111mv - 04-12-2017 19:06:11
Graphic equalizer that can control not only transmission frequency characteristics but also frequency characteristics of reverberation time.
Frequency equalizer (F.EQ) is independent left and right and has 12 elements.
In addition, the control range is a 2 step switching type of ± 12 dB and ± 6 dB.
In SEA-R7, a delay time equalizer (D.T.EQ) of left and right independent 5 element composition is carried. This equalizer produces a delayed signal by the electronic delay circuit adds reverberation by frequency to the main signal through a bandpass filter of 5 bands so that the delayed signal level and the decay time can be controlled continuously . Level is 0 dB for main signal and decay time is 0.04 - 1.2 s.
In addition, depending on the position of the volume the Depth indicator changes continuously from green to red, you can check the approximate reverberation time.
If you press the cross switch, you can invert the phase of the delayed signal and swap left and right.
It is equipped with two tape circuits, SEA recording/playback, SEA dubbing, simultaneous SEA recording of two lines, etc. are possible.
Страницы: 1
Читают тему
