Страницы: Пред. 1 2 3
Появился СС 3.4 !
Ну что, всё подтверждается:
http://www.minidisc.org/minidisc_faq.html#_q82
What restrictions does NetMD impose on transfers?
SP-mode Quality not Available Users can create SP, LP2 and LP4 mode tracks on Minidisc through OpenMG Jukebox downloads, but audio imported into OpenMG Jukebox (from CD, MP3, etc. sources) is converted and stored on the PC only in LP2 or LP4 format ATRAC3 files. So even when these files are downloaded onto the MD as SP mode tracks, the tracks cannot exceed LP mode quality. NetMD downloads through Simple Burner create only LP2 or LP4 mode tracks.
SP-mode Quality not Available!!! Во как!!! Наиполнейший отстой. А ведь этот формат (Atrac Type-R 292) актуален, используется он в том числе и в профессиональных rack mount моделях MD дек. Вообще считаю, что появление Atrac3plus больше связано с удобством (скорость передачи данных), чем с качеством звука, звучит он не лучше (вспомним хотя бы довольно отстойный Hi-LP!!!). Вот ещё интересно:
What is known about the information transferred over the USB link?
Encrypted PCM transfers for SP mode tracks: Judging from the careful experiments of Lance Birch, it appears that when NetMD downloading is being used for creating Minidisc SP mode tracks, the OpenMG software decompresses the [always LP2 or LP4 mode] PC file to standard 16bit, 44.1kHz PCM audio, encrypts it, and downloads that. The fact that PCM is being used for recording SP mode tracks is heartening since it indicates that NetMD downloads could retain SP mode audio quality, given the right PC software. Though current NetMD recorders reportedly offer only 1.6x speed downloading for SP mode tracks, USB 1.1's 12Mbps bandwidth would allow downloads at up to 8x realtime. Certainly the technology in Sony's MXD-D40 4x speed CD->MD dubbing deck could be directly applied for this purpose.
OpenMG software decompresses the [always LP2 or LP4 mode] PC file to standard 16bit, 44.1kHz PCM audio, encrypts it, and downloads that. т.е. на дивайс вдувается обычный PCM полученый из LP2!!! В этом ключе и скорость записи становится понятной.
Да, стоило мне полдня файлы сравнивать, чтобы потом за 5 минут всё это на minidisc.org найти:))) Выходит мы все, ребята это описание не читали, а ещё знатоками прикидываемся:)))
CC 3.4 делает так же. Похоже проблема в самом модуле OpenMG, который не признаёт других битрейтов кроме LP2 и LP4. Что, собственно и повелось ещё со времен выпуска NetMD. Я тоже провел иксперимент и увидел то же самое - ВАВ исходным размером 45 Мб конвертится в ОМА размером 4 Мб, что соответствует компрессии 1:10 (LP2), а никак не 1:5 (SP) Да что там говорить  - сам СС подтверждает, что данный файл кодирован мАТРАЦ3 с битрейтом 132 кбпс.
Надеюсь соня все таки сделает патч на OpenMG дабы можно было скидывать натуральный СП на плеер. Или найдется добрый хакер, который напишет маленькую программульку только для записи СП....
В общем  я уже запостил объяву про продажу своего RH10, буду брать RH1, он хоть в реалтайме сможет нормальный СП записать.............
Программного кодека на мАТРАЦ нет, есть только на мАТРАЦ3, попробую установлю, может он позволяет использовать СП-шный битрейт, но как это использовать в дальнейшем, чессно говоря не представляю.
Также непонятна ситуация с "независимым" тестированием - тут в форуме кто то по моей просьбе делал - утверждал, что усё пучком - записи не отличишь ?...
Рыдаю.
Всех благ.
На 21. "Независимым" тестирование можно назвать с большой натяжкой, тем более, что я сразу предупредил о субъективности. А вот что касается вольных переводов и скоропалительных выводов, скажу лишь, что файлы записанные в СС3.4 как OpenMG Audio, весят по 30-40 мегов. И где-же компрессия в 1:10???
Не суть - зависимое или независимое, важно было узнать мнение. А оно сводилось к тому, что разницы не было. Я, в общем то претензий не предъявляю. Рыдаю ещё раз.
Насчёт ОпенМыГи - она же в разных формах бывает. Адвансед Лосснех, например, тоже много места жрёт. Или как только ты зацепил Copy Protection на ВАВ, он тоже становится ОпенМыГа....
Пока рождается только одна идея - если у сони принципиально нет софтового кодека матрац1, можно кодировать звук для SP кодеком матрац3+. Вариантов 2 - либо ломать самому, либо писать в соню, дабы они в СС (5.0  ???) впузырили такую фичу. От них же не убудет ? Так или иначе звук будет скомпрессирован, то есть нет проблем по авторским правам.
Всех благ.
