| Цитата |
| в меню HDMI select есть два пункта- YCbCr и RGB-цветность |
• RGB-Expand (Image data values in RGB-Expand format range between 0 (black) and 246 (white).)
• YCbCr-1 (4:4:4)
• YCbCr-2 (4:2:2)
Select one of the above with the ENTER button.
Note
• The formats available for HDMI outputs depend
on the connected TV or projector. For details,
see the user’s manual of your TV or projector.
• Only RGB-Normal and RGB-Expand can be
selected for DVI outputs.
• When black rise to the surface depending on
the display, black Setup in the Video Adjustment
set to OIRE.
• YCbCr-1 (4:4:4) sends 8 bit data. YCbCr-2
(4:2:2) sends 10 bit data. If your TV or
projector supports YCbCr-2 (4:2:2), you can
enjoy the superior image quality of full 10 bit
processing.
